 Post subject: ST1000LM014 SSHD - request spin / disc table recovery
PostPosted: November 5th, 2026, 17:06
Hi everyone,
I have a Seagate ST1000LM014 SSHD that I can’t access from either Linux or Windows.
I connected it via the TTY interface. On startup, I get this output:
Rst 0x40M
Servo Processor Is Reset.
(P) SATA Reset
Request spin / disc table recovery
ASCII Diag
TCC:001A
mode
Strt Cln1
ABORT!
OpCode = 00000000
SenseCode = 03310000
ReadyStatusFlags = 0002A1A1
Here is the output with additional version information:
F3 T>
Kahuna+,DieShrnk, nQNR, ASD WPin+FFB+Combo+PSpin, 8/16/32GB
Product FamilyId: 72, MemberId: 01
HDA SN: W771H0Q2, RPM: 5408, Wedges: 100, Heads: 4, OrigHeads: 4, Lbas: 00000E8E0DB8, PreampType: B6 04
Bits/Symbol: C, Symbols/UserSector: BEB, Symbols/SystemSector: 1A5
PCBA SN: 0000M543BUB3, Controller: LUXORLPLUS_2_0( 203)(FF-FF-FF-F, Channel: STX_DUNRAVEN, PowerAsic: MCKINLEY MOBILE PLUS Rev 8C, BufferBytes: 4000000
Package Version: KH9T80.LVM3.J701DJ.LVD4, Package P/N: 100773086, Package Global ID: 00210313,
Package Build Date: 02/09/2015, Package Build Time: 13:30:44, Package CFW Version: KH9T.LVM3.00809636.00210313,
Package SFW1 Version: C804, Package SFW2 Version: B804, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 02091330, CustomerRel: LVD4, Changelist: 00809636, ProdType: KH9T.LVM3, Date: 02/09/2015, Time: 133044, UserId: 00210313
Servo FW Rev: B804
TCG IV Version: n/a
RAP FW Implementation Key: 16, Format Rev: 0004, Contents Rev: 06 01 03 00
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled v. 4.7.01.0000000000000017
- LTTC-UDR2 disabled
- SuperParity disabled
- Humidity Sensor disabled
- Background Reli Activity Critical Event Logging disabled
- Torn Write Protection disabled
Does anyone have suggestions on what I could try, or an idea of what might be wrong?
I don’t know much about SSHDs, but I suspect there could be an issue with the flash memory.
I also have a donor drive with a near manufacturing date.
If needed, I can try to provide an ROM dump.
 Post subject: Re: ST1000LM014 SSHD - request spin / disc table recovery
PostPosted: November 6th, 2026, 2:56
https://blog.acelab.eu.com/how-to-fix-a ... -chip.html
PostPosted: November 8th, 2026, 15:58
I wish I had access to PC-3000. For me it is more a Homelab repair.
Unfortunately I also noticed the donor dive is a year apart.
I attached the PCBs for comparison. The patient is on the left. The donor is in the right.
Any things I could try?
File comment: PCBs for comparison
PostPosted: November 9th, 2026, 16:44
You'd need someone to create a modified version of the ROM for you.
This means you'd need to be able to read and write to the ROM module.
If this is accomplished, you'd then be able to use the donor PCB after some terminal commands.
PostPosted: November 9th, 2026, 18:37
I should supplement and say, the above instructions are specific to replacing the PCB - not your OP.
Users browsing this forum: Google [Bot] and 117 guests
