 Post subject: ST24000NM002H - 24 TB
PostPosted: November 10th, 2026, 8:32
I have two working drives that were working in a USB cradle. One is a Seagate EXOS X24 - ST24000NM002H - 24 TB (FW SE05) (the other is described in a separate thread).
In Windows, the drives appear as unallocated space. I can't initialize the drive or create partitions.
Using Viktoria, I can't read the S.M.A.R.T. itself; I only see S.M.A.R.T. logs.
The data in this case is irrelevant (I only stored binary copies there, which I made a new copy of).
 Post subject: Re: ST24000NM002H - 24 TB
PostPosted: November 10th, 2026, 14:08
Answer hidden inside your USB cradle
Angel Data Recovery
PostPosted: November 10th, 2026, 14:33
I tried another USB adapter, and I also connected it directly via SATA. Unfortunately, I’m still experiencing the same issue.
PostPosted: November 10th, 2026, 15:19
Can you read the data? If you can't access the SMART attributes via SATA, that would suggest a firmware problem.
PostPosted: November 10th, 2026, 15:44
The data is not accessible. I have MRT — is there a chance to recover the drive after unlocking the ROM?
PostPosted: November 11th, 2026, 7:02
You may start with posting terminal output.
PostPosted: November 11th, 2026, 8:39
Which original USB adaptor it was?
Angel Data Recovery
PostPosted: November 11th, 2026, 10:24
orignal im use this
https://www.amazon.pl/Unitek-Stacja-klo ... 054&sr=8-9
PostPosted: November 11th, 2026, 17:52
I have seen several USB top load boxes but some older models might have problems with larger capacity disks. This is why I have so many models of various single 3.5" disk enclosures in case one works.
The headache is getting past possible firmware issues is the cost of a large disk for a duplicate. The ST24000NM002H is a lot of data.
PostPosted: November 11th, 2026, 19:34
What triggers you?
PostPosted: November 13th, 2026, 13:09
What triggers you?
The price for higher capacity hard disks has risen to insane heights.
PostPosted: November 14th, 2026, 6:24
it would be much better if you share terminal log of this drive
Data Recovery Pakistan
Users browsing this forum: Google [Bot] and 268 guests
