 Post subject: ST24000NM002H - 24 TB
PostPosted: Yesterday, 8:32
I have two working drives that were working in a USB cradle. One is a Seagate EXOS X24 - ST24000NM002H - 24 TB (FW SE05) (the other is described in a separate thread).
In Windows, the drives appear as unallocated space. I can't initialize the drive or create partitions.
Using Viktoria, I can't read the S.M.A.R.T. itself; I only see S.M.A.R.T. logs.
The data in this case is irrelevant (I only stored binary copies there, which I made a new copy of).
 Post subject: Re: ST24000NM002H - 24 TB
PostPosted: Yesterday, 14:08
Answer hidden inside your USB cradle
Angel Data Recovery
PostPosted: Yesterday, 14:33
I tried another USB adapter, and I also connected it directly via SATA. Unfortunately, I’m still experiencing the same issue.
PostPosted: Yesterday, 15:19
Can you read the data? If you can't access the SMART attributes via SATA, that would suggest a firmware problem.
PostPosted: Yesterday, 15:44
The data is not accessible. I have MRT — is there a chance to recover the drive after unlocking the ROM?
PostPosted: Today, 7:02
You may start with posting terminal output.
PostPosted: 30 minutes ago
Which original USB adaptor it was?
Angel Data Recovery
Users browsing this forum: Google [Bot] and 48 guests
