November 10th, 2026, 8:32
November 10th, 2026, 14:08
November 10th, 2026, 14:33
DR-Kiev wrote:Answer hidden inside your USB cradle
November 10th, 2026, 15:19
November 10th, 2026, 15:44
fzabkar wrote:Can you read the data? If you can't access the SMART attributes via SATA, that would suggest a firmware problem.
November 11th, 2026, 7:02
November 11th, 2026, 8:39
Pi0tR wrote:DR-Kiev wrote:Answer hidden inside your USB cradle
I tried another USB adapter, and I also connected it directly via SATA. Unfortunately, I’m still experiencing the same issue.
November 11th, 2026, 10:24
DR-Kiev wrote:Pi0tR wrote:DR-Kiev wrote:Answer hidden inside your USB cradle
Which original USB adaptor it was?
November 11th, 2026, 17:52
November 11th, 2026, 19:34
Hardcore Games wrote:I have seen several USB top load boxes but some older models might have problems with larger capacity disks. This is why I have so many models of various single 3.5" disk enclosures in case one works.
The headache is getting past possible firmware issues is the cost of a large disk for a duplicate. The ST24000NM002H is a lot of data.
November 13th, 2026, 13:09
HaQue wrote:Hardcore Games wrote:I have seen several USB top load boxes but some older models might have problems with larger capacity disks. This is why I have so many models of various single 3.5" disk enclosures in case one works.
What triggers you?
November 14th, 2026, 6:24
Pi0tR wrote:fzabkar wrote:Can you read the data? If you can't access the SMART attributes via SATA, that would suggest a firmware problem.
The data is not accessible. I have MRT — is there a chance to recover the drive after unlocking the ROM?
