Help with Seagate 7200.11 CC1H serial connection
November 16th, 2026, 13:55
I have 4 failed Seagate Barracuda 7200.11 drives. Two have firmware SD35 (1TB) and two have CC1H (1.5TB).
I have successfully repaired the two SD35 drives using the BSY serial fix.
I cannot get serial to respond on either of the CC1H drives. Their model #s are ST31500341AS. Putty terminal just shows a blank screen and CTRL-Z does not bring up the command prompt. I let the drive run for a bit and received nothing over TX from the drive.
I am using a 3.3v usb to ttl with 38400 8n1 which, again, worked perfectly fine on the two 1TB drives.
Any ideas?
On a side note, while checking voltages, i noticed that the 7200.11 pins measure the following voltage left to right, looking at the connectors, sata on the right.
1. 2.6v
2. GND
3. 2.6V (TX)
4. 5.0v (RX)
This 5.0v measurement is present on all 4 drives on the RX pin.
Re: Help with Seagate 7200.11 CC1H serial connection
November 16th, 2026, 17:20
There's a 99.9% chance this drive has bad heads, which is why it doesn't output anything to the terminal. This is typical for this particular hard drive model and can't be fixed using the known method for 7200.11 hard drives.
November 17th, 2026, 15:15
I have seen many 7200.11 with damaged heads/platters
I learned not to trust valued data to one copy
November 17th, 2026, 18:15
Hardcore Games wrote:I have seen many 7200.11 with damaged heads/platters
"learned" == "Trained"
