 Post subject: ATA Security locked Seagate IronWolf Pro 10TB
PostPosted: November 17th, 2026, 14:41
Hi everyone,
I bought a lot at a public auction (from ALLIANZ): a decommissioned Synology NAS (DS1817+) with 6x Seagate IronWolf Pro 10TB drives inside.
I have the invoice and the auctioneer’s certificate, so this is a legitimate purchase.
5 of the 6 drives are perfectly healthy (clean SMART, no reallocated sectors, readable). The 6th one is ATA Security locked and I can’t get past it.
Drive: ST10000NE0004-1ZF101, Firmware EN01, SATA, 9.1TB usable, SerialNumber :ZA22LWJV
System: fresh Debian 13 install, drive connected directly to an ASRock B550M Pro4 SATA port. (no HBA)
dparm -I output (relevant part):
Security:
    Master password revision code = 65534
        supported
        enabled
        locked
    not     frozen
    not     expired: security count
        supported: enhanced erase
    Security level high
    866min for SECURITY ERASE UNIT. 866min for ENHANCED SECURITY ERASE UNIT.
It’s locked but not frozen, so I know a straight unlock attempt should theoretically work with the right password, i just don’t have it.
All attempts to unlock with hdparm or sedutil-cli return the generic
SG_IO: bad/missing sense data
message, and the drive remains locked every time I re-check with hdparm -I
Is there a way to unlock it ?
 Post subject: Re: ATA Security locked Seagate IronWolf Pro 10TB
PostPosted: November 18th, 2026, 2:23
security erase should wipe the disk and remove the lock in this case...
PostPosted: November 18th, 2026, 10:24
This is what happend when i try to do a secure erase.
root@xxx:~# openSeaChest_Erase -d /dev/sg0 --ataSecureErase normal --confirm this-will-erase-data
openSeaChest_Erase - openSeaChest drive utilities - NVMe Enabled
Copyright (c) 2014-2024 Seagate Technology LLC and/or its Affiliates, All Rights Reserved
openSeaChest_Erase Version: 4.6.0-8_0_1 X86_64
Build Date: Oct 17 2024
Today: 20261118T152245 User: root
/dev/sg0 - ST10000NE0004-1ZF101 - ZA22LWJV - EN01 - ATA
ATA Security Erase
Starting ATA Security Erase using User password:  "SeaChest" (User)
        Current Time: Wed Nov 18 15:22:45 2026  Drive reported completion time:  14 hours 26 minutes from now.
        Estimated completion Time : Thu Nov 19 05:48:45 2026
        Please DO NOT remove power to the drive during the erase
        as this will leave it in an uninitialized state with the password set.
        If the power is removed, rerun this test with your utility.
        Upon erase completion, the password is automatically cleared.
        ATA Security erase failed to complete after Command Time (ms): 147.77
Also more informations :
root@xxx:~# openSeaChest_Security -d /dev/sg0 --ataSecurityInfo
openSeaChest_Security - openSeaChest drive utilities - NVMe Enabled
openSeaChest_Security Version: 3.4.1-8_0_1 X86_64
Today: 20261118T152725 User: root
====ATA Security Information====
Security State: 4
        Enabled: True
        Locked: True
        Frozen: False
        Password Attempts Exceeded: False
Master Password Capability: High
Master Password Identifier: 65534 (may be set to manufacture master password)
Enhanced Erase Time Estimate:  14 hours 26 minutes
Security Erase Time Estimate:  14 hours 26 minutes
All user data is encrypted: False
Restricted Sanitize Overrides ATA Security: False
SAT security protocol supported: False
PostPosted: November 18th, 2026, 11:08
My understanding of the ATA standard is that the SECURITY ERASE UNIT command requires that the password be supplied to the drive before it will initiate the erasure.
PostPosted: November 18th, 2026, 11:16
Basically it should not require the pw.
The reason SeaChest is trying to set it is because it thinks it is not set, and it fails at that very step, not at the security erase.
This is because SE is a good, and the fastest way to erase any drive, but if the drive has no pw, it must be set first, otherwise SE cannot be started.
But since this drive is already locked, this step should be skipped and only commands SecurityErasePrepare and SecurityErase should be sent.
PostPosted: November 18th, 2026, 11:20
Read the spec. If there is no password, then you must set one before the SECURITY ERASE UNIT command will execute. If there is an existing password, then it must be supplied by the command.
PostPosted: November 18th, 2026, 12:00
@fzabkar: agreed, and the timing backs that up, my erase attempt failed in 147.77ms, while the drive itself estimates 14h26min for the operation. That’s consistent with an immediate command abort (password mismatch), not a failure at a separate SECURITY_SET_PASSWORD step.
@pepe: the drive reports Enabled: True, meaning a password is already set i guess, so the “no password yet, must set one first” path you’re describing shouldn’t apply here. Do you have an example of SECURITY ERASE UNIT succeeding on a drive that was already Enabled: True/Locked, without supplying the correct password? That would help clarify whether this is a real exception or a mix-up with the “no password configured” case.
PostPosted: November 18th, 2026, 14:07
indeed, the command needs either the user or the master pw.
Since user pw is not known, your only chance is that master pwd is not changed, but this should be the case as the revision code is 65534.
So using the default master pwd it should work.
the default master pwd is
SeaGate.........................
as in, 32 bytes altogether, SeaGate + '.'*25
PostPosted: November 18th, 2026, 14:28
One other method might be to use the PSID to perform a cryptoerase. I don't know if that circumvents any password.
PostPosted: November 18th, 2026, 14:38
It used to be 25 spaces. Has this changed?
PostPosted: November 19th, 2026, 5:11
i just picked a random fw to check, it was actually from an M11 drive and its master pw was like i said. Now i checked some Cimarron, which is closer to the OP's drive, these store things differently, and it seems only hashes are stored. So it would require some deep investigation how these hashes are generated. The hashes differ on different drives even though the pwd revision code is FFFE, so there might be some salting as well.
Anyway, it is worth trying SeaGate + dots and spaces...
PostPosted: November 19th, 2026, 15:45
root@xxx:~# openSeaChest_Security -d /dev/sg1 --unlockATASec --ataSecPassword "SeaGate                         " --ataSecPassType user
Today: 20261119T204240 User: root
/dev/sg1 - ST10000NE0004-1ZF101 - ZA22LWJV - EN01 - ATA
Attempting to unlock security with password =  "SeaGate                          " (User)
Unable to unlock drive with password =  "SeaGate                          " (User)
Failed to unlock ATA security.
root@xxx:~# PASS="SeaGate$(printf '%.0s ' {1..25})"
root@xxx:~# openSeaChest_Security -d /dev/sg1 --unlockATASec --ataSecPassword "$PASS" --ataSecPassType user
Today: 20261119T204257 User: root
Nice try! :roll:
Users browsing this forum: Google [Bot] and 90 guests
