Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST1000LM014 SSHD - request spin / disc table recovery
PostPosted: Yesterday, 17:29
Rendersmith wrote:
I'm not sure if the original dump was correct.
It was correct. F3RomExplorer validated every checksum and CRC.
PostPosted: Today, 3:47
fzabkar, As far as I remember, for the correct calculation of the CRC, the CPRS modules must be unpacked. I never got around to it...
PostPosted: Today, 8:56
@SWM, thanks, I just confirmed your observation. Strangely, I don't need to unpack the CPRS code in the SFW segment -- both CRCs are valid for the compressed code.
PostPosted: Today, 11:17
The attached ROM has all the correct sums and CRCs. It only remains to be seen whether my two hacks are valid.
ST1000LM014_sshd_patient_rom_CRC_7.7z [675.32 KiB]
Downloaded 9 times
PostPosted: Today, 15:10
Thank you!
I executed these Commands
Request spin / disc table recovery
ASCII Diag mode
F3 T>/O
F3 O>I
ALF Parametric Tables Preserved
Flash was erased and ALF Tables have successfully been initialized
F3 O>
After that do I need to flash the original Firmware back again?
PostPosted: Today, 15:15
I'm not a data recovery pro, but that other thread would suggest that you do need to restore the original ROM contents.
Good luck, anyway.
Users browsing this forum: Google [Bot] and 215 guests
