Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST1000LM014 SSHD - request spin / disc table recovery
PostPosted: November 21st, 2026, 17:29
Rendersmith wrote:
I'm not sure if the original dump was correct.
It was correct. F3RomExplorer validated every checksum and CRC.
PostPosted: Yesterday, 3:47
fzabkar, As far as I remember, for the correct calculation of the CRC, the CPRS modules must be unpacked. I never got around to it...
PostPosted: Yesterday, 8:56
@SWM, thanks, I just confirmed your observation. Strangely, I don't need to unpack the CPRS code in the SFW segment -- both CRCs are valid for the compressed code.
PostPosted: Yesterday, 11:17
The attached ROM has all the correct sums and CRCs. It only remains to be seen whether my two hacks are valid.
ST1000LM014_sshd_patient_rom_CRC_7.7z [675.32 KiB]
Downloaded 15 times
PostPosted: Yesterday, 15:10
Thank you!
I executed these Commands
Request spin / disc table recovery
ASCII Diag mode
F3 T>/O
F3 O>I
ALF Parametric Tables Preserved
Flash was erased and ALF Tables have successfully been initialized
F3 O>
After that do I need to flash the original Firmware back again?
PostPosted: Yesterday, 15:15
I'm not a data recovery pro, but that other thread would suggest that you do need to restore the original ROM contents.
Good luck, anyway.
PostPosted: Yesterday, 16:57
I've been assuming that your drive doesn't attempt to spin. I hope that is/was the case, otherwise I may have been wasting your time.
PostPosted: Yesterday, 17:32
Well, it did spin in the first place.
I flashed the original rom again. But no luck, I can't access the data.
It continues to display "Request spin / disc table recovery"
But a thing changed:
As written in my first post I had this Output.
Strt Cln1
ABORT!
OpCode = 00000000
SenseCode = 03310000
ReadyStatusFlags = 0002A1A1
this is gone
it makes this over time:
TCC: 001D
TCC: 001E
TCC: 001F
TCC: 0020
PostPosted: Yesterday, 20:00
Well, I did waste your time. Sorry.
In my defence, I did give you a chance to correct my misunderstanding:
Since your drive doesn't spin, I would patch the patient ROM (on the patient PCB) so that you can then initialise the NAND flash. That's unless I'm misunderstanding something.
I believe those TCC numbers are the IDs of several overlays in the reserved System Area (SA) on the platters. It suggests that the drive is unable to reach the SA.
Users browsing this forum: ccc and 79 guests
