Toshiba MK4025 GAS Stucking Motor Problem
March 27th, 2006, 5:42
Last day come to me a Toshiba 40 GB with above series.. This Drive Can not spin as well. I check PCB .. there is no problem with the PCB... Then I try to open its HDA and found it is very hard to sppin the motor. seem like a bad bearing...What must I do for this Drive.. I dont have any donor drive or other. So i think . If I can put some oil to the bearing. I think the motor will spin well again. But I find nowhere I can put some oil inside bearing... What must I do .. Please help me...
March 27th, 2006, 9:08
i think that those hdds dont have ball bearing, have fluid bearing
cheers
March 28th, 2006, 9:52
if fluid bearing.. what must I do
