 Post subject: Is there a trick to WD head stack alignment?
PostPosted: May 9th, 2006, 10:45
I am still relatively new to disassembling disks. As a self teaching lesson I have disassembled, removed the heads and reinstalled the same heads in several drives. Currently I am working on what was a fully functional WD1200. Every time I reassemble a drive it continues to knock. Obviously the heads are not correctly aligned. I have tried magnet shifting, HDA shifting through a lever (joystick?) assembly screwed into the top screw. But no luck. Is the alignment so critical that I will never be able to get such drives to align. Should I give up on head transplants or do you just have to spend hours shifting things until it happens? What are the indications that you are getting close?
Users browsing this forum: No registered users and 72 guests
