Hitachi IC25N020ATMR04-0
May 27th, 2006, 12:34
Hy all people here does anyone had a problem similar like me hitachi in IC25N020ATMR04-0 ?
Symptom :Not knock sound, when the heads are released from ramp zone go to platter to read some one and then return to the ramp zone and motor still running. then show in ATA register´s (DRDY DSC)
Show problems at Loading Module Tables, Loading Open module table, and Error initializing zone allocation table Module zone its not found
So im try to access with Open Dir, RESF.rpm and zone.rpm and after loaded show ok . IM try to check SA but all modules show me Error UNC and Error loading Techno Zone.
NVRAM show OK
