 Post subject: Brown block - ERASE WAITs <350
PostPosted: June 29th, 2006, 12:13
Greetings,
Using MHDD, erase waits is set to >350ms by default. Can i change to >150 and if so where?
Since the program is set to erase waites > 350, is there any plans for creating its own color block for those from range 150-350?
Currently, when i erase waits, i re run scan and it still shows the brown blocks because erase waits only erases >350, so there are still some brown ones left that are <350 but > 150.
Also, is there any difference using this program on Laptop hard drives?
thnx
Users browsing this forum: Google [Bot] and 65 guests
