 Post subject: Seagate U6
PostPosted: August 14th, 2006, 15:34
I had a problem with Seagate U6
Problem : 7 Knock´s then turn off
Show in first
Head Mask 0701 0601 0501 0401 0301 0201 0101 001
Im do it:
Replace Head from a good Donnor same configuration
And knock dissapear,
Show
Intf tsk rst 1024k x 16 buffer detected
Ref 0152 - Hd Msk 0A00 - Switch to full int.
Ready
Err= 0016
BSY still on
Does any one know some thanks for all u info and help!!
Sinceraly
Alberto
 Post subject: Solve it
PostPosted: August 22nd, 2006, 23:07
:D
Solve it
Only a problem of position!!!
 Post subject:
PostPosted: August 27th, 2006, 6:33
i think u r right reposition the head and the drive will work fiine
 Post subject:
PostPosted: August 27th, 2006, 7:42
Hi beto,
did you solve the issue,kindly explain ,what you did
Amarbir
 Post subject:
PostPosted: August 27th, 2006, 13:31
Only check what happend, when head go out from the land zone to search the servo mark and SA , then im check its need to adjust the MHA , head stack and magnet position
this solve my problem after exchange head
 Post subject:
PostPosted: August 27th, 2006, 17:07
oh i seeee
Users browsing this forum: Google [Bot] and 88 guests
