MFT Records
September 11th, 2006, 21:40
I need to rebuild a corrupted MFT entry (it's a directory within a directory)
anyone got any good links to a byte for byte breakdown of how MFT record entries are structured
Thanks in advance
September 12th, 2006, 1:45
Here is one I used to use, but it is somehow different now.
http://www.linux-ntfs.org/content/view/103/42/
or I can send U the old one zipped, this old one seems to be more convenient at first glance.
Mft Records
September 12th, 2006, 2:21
Thanks Pepe
looks like this may take some time to digest :)
Hy
September 12th, 2006, 16:52
in my cases, some times when im get a Disk with MFT or file system damaged,or overwritting some times im check the system overwrite put the original sector in another part,of the disk , sometimes on the end, middle, or after the overwritting sector´s u can try to find MFT original searching by header of the MFT with a sector edit program im use winhex for this task with template analyze.
Like pepe this could help u, this help me to analyze the MFT structure when im search for headers for MFT
http://www.ntfs.com/ntfs_basics.htm
