 Post subject: PCB
PostPosted: November 27th, 2006, 16:59
Hi to all!
PCB HDD WD400BB-23DEA0 ITS BAD checked by pc3k
PCB HDD WD400BB-71DGA0 GOOD
Are they compatible?
Will not case be(go) because?
:roll:
:idea:
Нет ничего невозможного
 Post subject:
PostPosted: November 27th, 2006, 18:47
yes it is compatable
 Post subject:
PostPosted: November 27th, 2006, 19:26
No, they aren't.
xxDExx and xxDGxx are not compatible.
 Post subject: Re: PCB
PostPosted: November 28th, 2006, 3:19
sempre wrote:
Hi to all!
:roll:
:idea:
I also think that they are not compatible...
but check the numbers on PCBs:
2060-00xxxx-yyy
Are they identical or not?
in case they are identical you must check
that the pcb ' s controlers ( MPU) are identical....
regards
 Post subject:
PostPosted: November 28th, 2006, 5:08
Yes, in one you have G and the other you have E, and that's not compatible.
 Post subject:
PostPosted: November 28th, 2006, 7:46
pepe wrote:
No, they aren't.
Thanks all helps!!
:idea:
PostPosted: November 28th, 2006, 8:02
2060-00xxxx-yyy
regards[/quote]
Hi gsimon!
but check the numbers on PCBs: yes identical!
thanks!!
:idea:
PostPosted: November 28th, 2006, 8:03
gsimon wrote:
sempre wrote:
Hi to all!
:roll:
:idea:
2060-00xxxx-yyy
regards
PLEASE GSIMON CHECK PM!
:idea:
 Post subject:
PostPosted: November 28th, 2006, 8:13
you have same numbers on pcb ?
what is it?
and have same numbers on MPU?
what is it?
give us all numbers....
 Post subject:
PostPosted: November 28th, 2006, 10:16
if all are same on both pcb
you have only diffrence
in flash eprom
change contents ( reprogram ) or whole eprom
 Post subject: PCB
PostPosted: November 28th, 2006, 11:13
in flash eprom
THANKS!
Please check PM!
:idea:
