Resolving System Area problem using MHDD
October 30th, 2006, 15:34
Hi all,
I read from MHDD documentation:
Q26: It seems that on my HDD every block is bad.
A: You have some kind of System Area problem. This is not fixable with standard MHDD commands.
I am wondering if SA problems are not fixable with standard MHDD commands so does it mean I can resolve it through different way (non-standard commands)?
So is there any way to fix SA problems using MHDD?
Regards,
Rafal
October 31st, 2006, 0:28
Hello raf-pl,
In general MHDD can't be used to work on service area.
As to my knowledge there is no freely available too which can do this for you.
MHDD has a batch scripting function in MHDD 4.5 and bellow.
This could in theory be used to pass commands to the ATA Controller to access the Service Area. But for this you must know what you are doing in service area and you must know script function in MHDD.
The other alternative are writing your own tool if you have lots of free time to develop and research and are proficient in programming or purchase PC 3000 or HRT.
I hope this helps.
November 9th, 2006, 16:50
Why dont you tell us more about your problem?Also tell what hard drive you have problems with?
November 12th, 2006, 3:48
I have a free software that can work with Service Area of WD.
http://d.turboupload.com/d/1201271/wd-sa.rar.html
Quick Check Modules In Reserved Area For WD ***
(C)NazYura Krasnodar 2005
This Utility Allows By Leaps And Bounds To Check
Modules Of The System Area Of The Disk, But So,
Find Modules Not Enumerated In Directory Sector.
(Utility Works Only On IDE2=Master Port)
Usage: Check_WD.com [>filename.log].
November 30th, 2006, 1:17
rameez,
your tool doesn't work for me. Have you been able to successful use it to retirve SA information?
I set drive to IDE2=Master Port
I tried several WD drives and I keep getting a busy error with this software.
Any Ideas :?:
