Seagate Need Help
November 30th, 2006, 23:37
Hi all hddguru,
here I get Seagate drive to recover data.
Here it show in terminal :
1024 x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Buzz - Head Mask FFFF - Switch to fill int.
Spin Ready
Error Reading Reserve Track Defect list
( --- the program show Normal Mode, but the terminal cannot show T>)
F>
F>U
F>R1
Code - A1 Track 0E37B.0.0D6 Sns 0D6
F>R2
Code - A2 Track 0E37B.0.1AA Sns 1AA
F>R4
Code - A3 Track 0E37B.0.0D5 Sns 0D5
F>j
Code - FF Track 0E37B.0.0D5 Sns 0D5
I try to Load LDR at the first time but Failed, it said Terminal timed out
Here another Information I generated from the terminal.
F>
Cmd Cyl Hd Sct Cnt Stbuf Segl Csct Cbuf Actv Ercd Rtry Flags
10 00000 00 0000 0000 0000 00 00D6 0FDD N A1 0017.ff.80 1802
F>Pgm=00 Trk=0000E37B(0000E37B).0(0).0D6(0D6) Zn=00 Err=A1 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=00000000
F>Age=00 Type=00 MxCyl=0000E386 MxHd=00 MxSct=280 BSz=0800 TCode=0000
Its really hard to understand how to fix seagate drive. :(
Hopefully somebody in here can help me solve this problem. cause I thinks this is Firmware problem.
Best regards,
Tony Heryanto Tjeng
December 3rd, 2006, 16:01
Hi!
I had one like this a while ago.
Turned out a head had crashed and had scraped the platter.
If you have the skill/equipment, open the drive and see if the filter (white cushion-type thing) is discoloured.
If so, then "bye bye data" :-(
