 Post subject: Green Block <150ms Good Bad ???
PostPosted: January 15th, 2007, 15:51
Testing SCSI drives and I get some <150ms should I format and retest???
If I get <500ms or >500ms I always format and erase then retest. Do I need to do so with <150ms??? :? Whats everyones opinion???
Thanks everyone. :D
 Post subject:
PostPosted: January 17th, 2007, 19:49
What model drive? Always the same block? Do you use the drive's built-in format before testing? It isn't a temp. recalibration is it?
 Post subject:
PostPosted: January 18th, 2007, 0:36
Most are IBM ESXS SCSI drives. Various areas show <150ms. Need to know what is industry standered. Or does it vary with each company??? Would some <150ms be acceptable.
The same model drive with some <150ms will format and clear these areas and others will not. Does this mean the ones that did not clear the <150ms are going bad because of weak areas???
Any <500ms and >500ms that do not clear are scraped.
I need to know what everyone thinks about <150ms and if they do not clear up is the drive GOOD or BAD???
 Post subject:
PostPosted: January 18th, 2007, 13:14
try low level formatting the drive of do write test with victoria .
Users browsing this forum: Majestic-12 [Bot] and 141 guests
