 Post subject: Help with two Seagate HDD
PostPosted: January 31st, 2007, 5:44
Hi everybody, I'm new in the forum, and I have a trouble with two components of the logic board of two hdds, the components burnt because of a power supply and I can't see what is the number of the component, the hdds are one barracuda 7200.9 300Gb and a Barracuda of 120 Gb, Image
If anyone of you HDDGurus could tell me what is the component maybe I'll can replace it. Thanks in advance.
PD.- Sorry for my English, and thanks again.
 Post subject:
PostPosted: January 31st, 2007, 9:00
hi, u can fix pcb by remove burn diod out of pcb, that way easy. Good luck
@ Repair_ HDD Recover DATA @
Add: Gác 2 Số 10 Hàng Bè Hà Nội Việt Nam
Đặc biệt: Cứu dữ liệu trong trường hợp ổ cứng chết Cơ.
Website: http://www.repair-hdd.com
Tel : 9177619-9263400
 Post subject:
PostPosted: January 31st, 2007, 9:10
Thanks for the reply, my friend, only one cuestion, i remove the diode and I replace it for what?, because i think if i let the pins without connection the PCB will not work. Thanks
 Post subject:
PostPosted: January 31st, 2007, 11:05
You don't need to replace it by anything.
 Post subject:
PostPosted: January 31st, 2007, 11:10
Ok, thanks again, then i suppose that I only have to remove the burnt component, don't need to join the contacts of the diode?. Thanks
 Post subject:
PostPosted: January 31st, 2007, 11:27
You do not have to join contacts. All you have to do is to remove the diode.
 Post subject:
PostPosted: January 31st, 2007, 12:22
Thank you all, hope this works.
Users browsing this forum: No registered users and 148 guests
