 Post subject: Dell Poweredge SC420 Maxtor 6Y080M0
PostPosted: February 19th, 2007, 22:29
Help appreciated
My Poweredge locked up Saturday. Reboot showed read error ctrl alt del required.
I downloaded MHDD per suggestion and started
It has found many UNC and AMNF
The drive is SATA. I do have second SATA drive bot no clone software.
What do i do?
 Post subject:
PostPosted: February 20th, 2007, 12:05
Can you please specify.
What for Configuration you are running on the Poweredge server?
RAID 0
RAID 1
RAID 5
JOBD
And is this OS drive, or file drive?
 Post subject:
PostPosted: February 20th, 2007, 18:23
Does drive recognise in BIOS OK?
If so then you may have bad sectors/partial head failure.
If not, you may have a firmware problem.
Either way, dont think pure software solution will cure.
You need to contact a DR recovery company, if you require data.
Sean
 Post subject:
PostPosted: February 20th, 2007, 19:16
RAID 0
RAID 1
RAID 5
JOBD
JOBD. OS and files.
Sean
Yes BIOS sees the drive. If I use a boot cd that has NTFS support it shows it as unreadable. I'd like to get back any files that are salvagable.
I know drive is not under warranty now
HDD Regenerator is still running
19143 bad sectors so far. Claims to have recovered all of them
 Post subject:
PostPosted: February 21st, 2007, 8:19
You can try a good cloning tool, with reverse sector clone function.
If this doesn't work, I would recommend sending it in for recovery.
 Post subject:
PostPosted: February 21st, 2007, 8:26
Stop the HDD regen.
All it does is add the dodgy/weak sectors to the G-List.
When that is full, then you have problems.
Get it sent in for professional imaging.
I can try for you, I have Deepspar imager.
Cheers
Sean
Users browsing this forum: No registered users and 93 guests
