 Post subject: changing plates instead of headstack?
PostPosted: February 20th, 2007, 21:11
hi, i was wandering if its less complicated to change the discs in a hdd instead of the heads.
 Post subject:
PostPosted: February 20th, 2007, 21:31
no
 Post subject:
PostPosted: February 20th, 2007, 21:42
then, i have a segate st3250823a and trying to get a donor. if a find one, just swap plates to recover the data?
 Post subject:
PostPosted: February 20th, 2007, 21:56
I meant it is not 'less complicated' to swap discs, that's the last thing one should do. (apart from slim drives)
But here I must warn U that if U have never done it before there is a very low probability U will succeed.
regards,
 Post subject:
PostPosted: February 21st, 2007, 8:10
don't swap platters.
If you will swap the heads, most likely you will damage something.
Also, it could be other problems, which you may not be aware of.
If the data on the drive is valuable, send it in to a professional data recovery company.
 Post subject:
PostPosted: February 21st, 2007, 8:15
Agree.
DO NOT swap platters, it is the hardest thing to do.
Also unless you have done it before, DO NOT try to swap heads.
Send to someone who can!
 Post subject:
PostPosted: February 23rd, 2007, 3:32
it would be more hard if there are more than 1 disc it is way better to swap heads .
Users browsing this forum: No registered users and 86 guests
