 Post subject: Common Seagate Problem
PostPosted: April 16th, 2007, 2:53
I have many hdd with a problem the hdd shows invalid serial no and capacity like if the original serial no is ST32041A then it shows sRT$)A3 and its capacity is 20gb sometimes it shows 40gb sometimes 10gb sometimes 28gb etc also it keeps on changing the serial no . I changed the pcb the drive become ok but i want to know which component was bad in pcb .
Thanks in advance .
 Post subject:
PostPosted: April 16th, 2007, 3:35
resistance networks !!
 Post subject:
PostPosted: April 16th, 2007, 6:38
Change Data cable
DF
 Post subject:
PostPosted: April 16th, 2007, 6:44
darkfroce1 wrote:
Change Data cable
DF
please read question properly..
Thanks & Regards
 Post subject:
PostPosted: April 16th, 2007, 17:16
Thank you i changed the faulty resistance lower to the ide connector it worked .
