 Post subject: 2.5" HDD WD800UE not mapped ion WXP
PostPosted: June 12th, 2007, 13:27
Hi everyone,
I am trying to make a 2.5" HDD WD800UE work, with not success. I bought a case to move it from a computer to other and connect it thru USB port.
The problem is that windows XP SP2 does not map it. I can see it in the device manager under HDDs section, but can not access to it from WXP. Do I have to initializate it? if so, HOW?
Thanks.
 Post subject:
PostPosted: June 12th, 2007, 14:08
You open up the computer management under "my computer" and then select the harddisk management (i dont know the correct english terms). There you can choose to initialize and format your disk.
Then XP should show it in explorer.
Regards,
Dobre
 Post subject:
PostPosted: June 12th, 2007, 18:54
If U have important data on the disk, do not format it, I would first create an image, then do DR by some piece of SW.
regards,
 Post subject:
PostPosted: June 13th, 2007, 22:00
Thanks, dobrevjetser.
Problem solved!! it was not mapped, basically because was not initialized.
Thanks again.
 Post subject: 2.5" HDD WD800UE not mapped in WXP
PostPosted: June 13th, 2007, 22:04
Thanks Pepe. It is a brand new disk, so it needed to be initialized from hard disk manager.-
Problem is now solved out with help of dobrevjetser
Thanks again guys. Very helpful!!
Users browsing this forum: Google [Bot] and 63 guests
