 Post subject: So Many Samsungs and No Clue ?
PostPosted: June 21st, 2007, 16:49
In India We Have Samsungs Everywhere .I Need Some People To Assist Me To Repair these .For starters
Model S0842N :Starts spinning Then Tries The Heads Movement But Fails Then Spins Down .Do These Have Safe Models How Can i analyse These fo That You May Help
Model SP0401N :spins Fine Heads Knock But Keeps Spinning .What To Do
 Post subject:
PostPosted: June 22nd, 2007, 0:14
Use terminal , and post here :D
 Post subject:
PostPosted: June 22nd, 2007, 3:25
Terminal For SP0842N ......
lltst 0000
SpnOk
spd: 0000 0000 0000
ADC: FFFF
DAC: 908F
H: +00000
SK C: 00012636
ENG>SRV>
SvoTbl Loaded
BD
FdtTbl Loaded
Sb
WriteSctLog -- buffer not valid
Terminal For SP0401N .............
SpnOk
DAC:+00018
H: +00000
SK C: 0000C45F
ENG>SRV> SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C28C
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C32C
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2CC
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C312
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C31C
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C318
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2B2
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2D3
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2C6
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2C3
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C35E
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C299
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2D9
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C31A
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C2F6
SR : +00000
SR : +00001
SR : +00002
H: +00000
SK C: 0000C294
 Post subject:
PostPosted: June 22nd, 2007, 10:49
SP0401 probably has head failure, U can try platter swap to a matching donor.
try a SW reset on the first one, does it get ready after?
 Post subject:
PostPosted: June 22nd, 2007, 11:03
Hi Pepe,
SP0401 = Platter Change ? or Head Stack Assembly Change
SP0842N = SW Reset [ Please Explain ]
 Post subject:
PostPosted: June 22nd, 2007, 12:57
in SP0401 U cannot change MHA without taking off the platter first, so it is much easier to swap the platter than the MHA.
This is the same with the slim maxtors...
SP0842:
what does it react on a SW reset? does it show DRD, DSC?
regards,
 Post subject:
PostPosted: June 22nd, 2007, 13:57
Lift the platter with handle and cautions, some times its possible a Head Crash on Samsung SP0411N too :?
Users browsing this forum: No registered users and 108 guests
