 Post subject: Toshiba MK4019GAX
PostPosted: June 23rd, 2007, 0:12
Hello to all hddguru.
A question its possible to read Microcode from a Toshiba PCB directly without HDA ? And write on a donnor PCB ? using terminal commands for example.
Because toshiba dont allow PCB swap´s
Sinceraly
Alberto
 Post subject:
PostPosted: June 23rd, 2007, 5:50
Don't think so.
You have to transfer the microprocessor (the "ARM" chip) to the donor PCB. :-(
 Post subject:
PostPosted: June 23rd, 2007, 20:46
As pcimage suggested, you need to swap the ARM processor chip as it contains adaptives for this drive. It's a very very difficult chip swap (80pins) and you really need an infrared soldering tool. Probably a 50/50 chance of it working.
Not much point in doing as Spildit suggests as you will still need to de-solder and re-solder the chip anyway.
 Post subject:
PostPosted: June 24th, 2007, 23:17
Hello spildit wich class of universal eeprom programmer do u suggest me for do this work?
cron
