 Post subject: Toshiba HDD is too small
PostPosted: June 25th, 2007, 15:32
Hi all,
i have a Thoshiba MK4019GAX. On the disk is printed 40 GB, but all the tools say 32GB. Cane someone explain that to me?
Details of the disk
Current date and time: 25.06.2007 21:24:58
Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com
Device details for TOSHIBA MK4019GAX FA004B [32 Gbytes]
Model: TOSHIBA MK4019GAX
Firmware Revision: FA004B
Serial Number: Z2FI7439T
PHYSICAL PARAMETERS:
LBA mode is supported
LBA-48 mode is not supported
Sectors available with LBA commands: 62,506,080
Sectors available with LBA48 commands: 0
Full device capacity: 32,003,112,960 bytes
SECURITY:
Security features is supported
The device is currently not locked
FEATURES:
SMART is supported
HPA (Host-protected area) is supported
AAM (Automatic acoustic management) is not supported
Streaming feature set is not supported
QUEUING:
Command Queuing is not supported by the device
 Post subject:
PostPosted: June 26th, 2007, 5:46
There are two commands in MHDD that will help:
1. NHPA
2. CONFIG (if NHPA won't work, but it should work for your drive)
 Post subject:
PostPosted: June 28th, 2007, 2:45
Hi... thanks for the answers, but i check the commands in MHDD and the BIOS, however all likes good...
some more infos to the disk: the 40GB disk is a spare part for a 30GB disk and i think to downsize the disk there is a tool available.
A technician in a repair center use a toool on a floppy, boot from the floppy and started a software to downsize the disk. I ask the technician... pls give me the software, but no chance.
someone a idea....
regards to all TOFU
 Post subject:
PostPosted: June 28th, 2007, 9:39
This can happen also because your BIOS doesn't support disks over 32GB.
Did you try this drive on another machine?
 Post subject:
PostPosted: June 28th, 2007, 12:12
Yes ,
Try On Other System .Possibly On Latest Board .As Far As Software You Can Use MHDD And Make The Size of The HDD To Any Size You Like
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 79 guests
