 Post subject: Newbie With Burnt Chip on WD Drive
PostPosted: July 5th, 2007, 23:01
Hi - this drive is a WD2000JB-00GVA0, DCM: DSBHCTJAA. I have a donor with the exact PCB match.
Here's a pic of the original drive with the burnt chip(motor controller maybe?). Question: Can I just pull the ROM chip and solder onto the donor? Or should I unsolder the burnt chip and replace it(though this seems near impossible since it has microscopic surface-mount leads)?
What do the pros do?
Thanks,
A
 Post subject:
PostPosted: July 5th, 2007, 23:49
U12 is the ROM chip. You should move it the donor.
 Post subject:
PostPosted: July 6th, 2007, 17:54
Hi Mate ,
Just Change the Rom Chip .If You Could Put the Drive In Safe Mode you Could Copy the Rom Via Pc-3000 And burn/write the same to donor ,Remember to backup the donor rom too.
Users browsing this forum: No registered users and 109 guests
