 Post subject: LOOKING FOR HDD CONTROLLER BOARD
PostPosted: July 11th, 2007, 12:05
Hi , I m actually a teacher and i make people technicians who fix computers. My Problem I have a external HDD DRIVE that someone fried when he plugged in the wrong power adapter. I took the HDD out of its USB casing and it turned out to be a DIAMONDMAX20 ST3160812A 160 GB
When i hooked it up to my Desktop comuter using IDE it did not power up. I think the board is Fried. Can someone tell me with wich one i can replace it or where i can get a comparable one ? Here is the Data :
DIAMONDMAX20 ST3160812A 160 GB S/N 5LS814QB Firmware : 3.AAK
Date Code > 07276 Site Code : WU PN: 9BD032-326 Any other Data needed ? SPACIVA ! Thank you ! Dankeschoen !
 Post subject:
PostPosted: July 11th, 2007, 13:24
Try to find another DiamondMax 20 with the same model name and Firmware code.
If it doesn't work right away then you will need to swap the ROM chip.
Users browsing this forum: No registered users and 108 guests
