 Post subject: ROM file needed for MHR2020AT
PostPosted: July 12th, 2007, 8:29
Hi!
I need a ROM file for a Fujitsu MHR2020AT
(to suit firmwware version x03-53B9)
I think some other "expert" has swapped the PCB to try and fix this drive. As the ROM info does not match the recorded F/W, and I don't have x03-53B9 ROM image.
Cheers
Sean
 Post subject:
PostPosted: July 12th, 2007, 8:54
Hey sean..........
I have modules and ROM for fujitsu MHR2020AT, but the f/w is FUJITSU MHR2020AT-30B8-NJ13T1C12NC4. :( . So, I don't think, would be of any use for you. :?
Well, but gimme some time, perhaps I could find something practically usable for you. :)
 Post subject: Re: ROM file needed for MHR2020AT
PostPosted: July 16th, 2007, 3:34
Thanks for your help, not found yet :-(
Anyone have this?
Cheers
PostPosted: July 16th, 2007, 6:04
I have what u want MHR2020AT 53B9. send your id as file uploading of hddguru is down
as u say Cheers :good:
DF
DF :)
www.datatracksystem.net
PostPosted: July 16th, 2007, 8:48
DF,
Thanks for the ROM file, it worked fine.
Now the HDD is ID correctly.
BUT.... Now I can see the REAL original problem, one of the heads is bad.
Now to tackle that problem, should be easy enough, donor permitting!
Cheers
Sean
Users browsing this forum: Google [Bot] and 63 guests
