RAID 1 hellllppp!
August 23rd, 2007, 7:52
hi gurus...i dont know anything about RAID ,hoping someone can help me out....i have network storage with 2 hdd set as mirrored RAID 1, one hdd now failed with bad sectors, the other hdd is good, how to get the data? just replace the faulty hdd and rebuild? :roll:
Re: RAID 1 hellllppp!
August 23rd, 2007, 8:55
What is the model of your network storage?
August 23rd, 2007, 8:57
If it's mirrored properly, then YES! :-)
August 23rd, 2007, 9:56
IF you have a RAID 1 means that you have a mirror disk, so you just plug the second drive at first drive and all the data will be fine.
if not boot you can config your Raid controler, but just plug in and works Fine.
August 24th, 2007, 5:56
thank you all
