 Post subject: Lacie Ethernet Disk
PostPosted: August 28th, 2007, 4:14
I have here a Lacie Ethernet Disk of 1 Tb, with 4 Seagate 250 Gb drives.
My costumer deleted some data, so I need to run any software on the partition.
As this is a NAS, through the network I can only access the shared folders.
Do you know any way to access partition on this NAS or the only way is to remove the drives and destripe the raid?
Thanks.
 Post subject: Re: Lacie Ethernet Disk
PostPosted: August 28th, 2007, 11:08
Could you mount the 4 drives in youre computer? if you cand, you can rebuild the xfs partition whit UFS explorer, but the most important you must know what kind of RAID have.
PostPosted: August 28th, 2007, 11:13
It's a RAID0, and it's NTFS file system.
I'm already mounting the drives and finding out raid parameters.
PostPosted: August 28th, 2007, 13:06
IF its RAID 0 , in NTFS you will able to find the files that you need .
good luck
