 Post subject: Laminar flow cabinet
PostPosted: September 19th, 2007, 4:59
Hi all,
i am interested in your thoughts about laminar flow cabinets, i am looking at setting up a clean room in our office, 2 choices are
1 laminar flow cabinet on our existing workbench, while these are certified to class 100 they are still open but are less complicated than a class 100 clean room with the uniforms etc,
option2, clean room but these are very expensive when set up correctly and as i am still getting into this i am trying to be careful with the initial spend till more work comes in,
then i thought mabye a laminar flow cabinet class 100 built into a closed room which could be made from gyprock and glass panel with antistatic vinyl on the floor, while this is not a clean room it would still be a class 100 area in the laminar flow cabinet, i see it as being a cleaner way then having a laminar flow cabinet in a larger room,
has anyone here gone down this path ? i would also be interested to know what setups people are using? and whether they had them professionally built or sourced materials themselves such as hepa filters/fans/ ESD walls and built them alone and then had them certified by an authority?
thx for all the help
 Post subject: Re: Laminar flow cabinet
PostPosted: September 19th, 2007, 8:25
If you want to have a class 100 place that cannot be contaminated, you can also use a glovebox. They exist in different sizes. Then the disk is completely isolated from the surroundings, but working with these gloves is not easy!
Best regards,
Dobre
Murphy was an optimist
Users browsing this forum: No registered users and 151 guests
