 Post subject: 1.8" Toshiba hard disk Pinout
PostPosted: September 27th, 2007, 6:41
I have uploded 1.8" Toshiba hard disk Pinout in datasheet section of files.hddguru.com. Very helpful.
Here is the link
http://files.hddguru.com/download/Datasheets/1.8%20%20hard%20disk%20datasheet/MK2004GALMK4004GAHTechnicalNotes-RevD.pdf
DF :)
DF :)
www.datatracksystem.net
 Post subject: Re: 1.8" Toshiba hard disk Pinout
PostPosted: September 27th, 2007, 23:06
thanks you friend
Спасибо
СУТИОНО / АПИНГ
PostPosted: September 28th, 2007, 1:07
You are welcome
DF :)
DF :)
PostPosted: September 28th, 2007, 5:47
Thanks, what's the purpose of this? What is a Pinout? Sorry but i'm still learning.
PostPosted: September 28th, 2007, 6:01
Pinout it the layout of all the pins; it describes where each pin is located and what it function is (what signal it carries).
Dobre
Murphy was an optimist
PostPosted: September 28th, 2007, 10:57
Hi to all.
I have an adapter of hdd 1.8"for IDE and perceived that they are equal to the connector of the CF, I can have access the CF with this adapter?
Or to have access hd 1.8"Of the READER OF CARD CF?
The bolts have the same function of the CF with HD 1,8"?
Нет ничего невозможного
PostPosted: September 28th, 2007, 11:54
sempre wrote:
Hi to all.
Look for doc CF
http://www.compactflash.org/cfspc4_1.pdf
PostPosted: September 29th, 2007, 13:51
Hi Guys i just finished the same.
I had to check a ipod hdd 1.8" .I haver the same converter the left side is pin 44 and the right side is pin 1 .If the 1.8" drive holes point towards you make sure the totally round hole is in the right side and the hole which is elongated is on the left .Then just yank then together .Its Done
Users browsing this forum: Bing [Bot] and 68 guests
