 Post subject: Compatible sata and pata pcb's
PostPosted: November 30th, 2007, 8:24
I have here a Seagate ST3320820A with damaged PCB, some chips get really hot.
But I can only find in a supplier a ST3320820AS PCB with same firmware.
Anyone has already tested to check if it's possible to make sata pcb compatible with pata?
Thanks.
 Post subject: Re: Compatible sata and pata pcb's
PostPosted: November 30th, 2007, 8:43
Hi
Already I made in hd maxtor sata of 80 gb for pcb IDE and gave certain! :ookay:
in seagate I still did not try... :?:
:idea:
Нет ничего невозможного
PostPosted: November 30th, 2007, 8:54
I did use a Seagate sata board on an occasion to recover a pata drive, and in my case it worked.
Dobre
Murphy was an optimist
PostPosted: November 30th, 2007, 10:39
But you had to swap ROM?
PostPosted: November 30th, 2007, 11:06
Not that i remember, but i had same partnumber-revision and FW version
Dobre
PostPosted: November 30th, 2007, 11:10
I only have same firmware version, but not same P/N.
Well, I'll try and let you know something.
Users browsing this forum: No registered users and 51 guests
