 Post subject: Low-Level Format internal error
PostPosted: February 3rd, 2008, 11:40
I am trying to do a low-level format to my HD.
The program show this message:
Current date and time: 03/02/2008 13:18:42
Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com
Device details for HDS722540VLAT20    V31OA60A    [41,17 Gbytes]
Details are unavailable: Internal error.
Please post this problem on http://forum.hddguru.com
Can I do a low level format anyway? Are there some risk?
I give more information:
BUS: ATA
MODEL: HDS722540VLAT20
FIRMWARE: V31OA60A
Serial Number: The program shows blank...
LBA: 80418240
SPEED: 7200 RPM
CHS:16383/16/63
And finally, I show you the SMART attributes screen showed by the program:
Current date and time: 03/02/2008 13:38:18
SMART Attributes for HDS722540VLAT20    V31OA60A    [41,17 Gbytes]
          Attribute                      Current   Worst    Raw       Note
Att: 1    Read error rate                   95       95          11
Att: 2    Throughput performance           100      100           0
Att: 3    Spin up time                     137      137     9175190
Att: 4    Number of spin-up times          100      100        1570
Att: 5    Reallocated sectors count        100      100          53
Att: 7    Seek error rate                  100      100           0
Att: 8    Seek time performance            100      100           0
Att: 9    Power-on time                     99       99       13691
Att: 10   Spin-up retries                  100      100           0
Att: 12   Start/stop count                 100      100        1563
Att: 192  Power-off retract count           99       99        2056
Att: 193  Load/unload cycle count           99       99        2056
Att: 194  HDA Temperature                  141      141      458791  (39 degrees)
Att: 196  Reallocate event count           100      100          56
Att: 197  Current pending sectors          100      100          29
Att: 198  Offline scan UNC sectors         100      100           0
Att: 199  Ultra ATA CRC Errors             200      200          27
Users browsing this forum: hawkinf, Majestic-12 [Bot], WebClaw and 62 guests
