 Post subject: NEED Modules for Fujitsu - MHV2120AT
PostPosted: February 7th, 2008, 6:38
Hi All,
I need Modules for Fujitsu 2.5" IDE - MHV2120AT - 120 GB
Firmware: 09DE5A-000000A0
 Post subject: Re: NEED Modules for Fujitsu - MHV2120AT
PostPosted: February 7th, 2008, 18:05
Hi DIAGS4711,
Ok, so you can get 10 000 sets of "modules" for this drive.
What you going to do when you get this files ?
PostPosted: February 8th, 2008, 5:58
Hello Coffeebean,
what do you doing with modules ?, ... i will hide in my garden.
Your question is very funny !? - The answer is very simple i will repair BAD module(s) !
In my case drive seems password protected, Modules 0c/0d (MA/SU) are damaged
or better not readable/writeable. Only Module 3D is really damaged (not readable) and
header of other modules seems OK, PCB is OK, passport is complete.
What do you think ?, it´s may be other problem ?
Have you the right modules for MHV2120AT-Firmware: 09DE5A-000000A0 ?
(by the way - i get not answer on my last reply from module request
MHT2080AT-Firmware 03B7-0022, have you this modules,too ?)
I hope you have the right modules and you will help me. - THANKS
PostPosted: February 8th, 2008, 7:43
Hi DIAGS4711,
Be my guest, write anything to your MHV or MHT,
3D, ROM as you please.
I just try to help, but if you must fux up a drive, just do it.
Just to be clear, I think you should not write anything from patient drive
to your MHV, but what do i know ?
Just try perfect good 100% working MHV and see what your pc3000 reports
about 3D and some other "modules"
PostPosted: February 8th, 2008, 14:29
Hi DIAGS4711,
As Coffeebean says but in a clear way is that pc3000 does not have support for those modules on that drive model.
Even Pc3000 UDMA has limited support on that specific model.
http://www.acelaboratory.com/pc3000.fujitsu2.5.php#tab1
Regards/ Bosse
http://www.rescue-it.se
Users browsing this forum: Majestic-12 [Bot] and 66 guests
