 Post subject: barracuda 7200.7 PCB repair
PostPosted: March 12th, 2008, 12:33
I have a ST3160021A that had a burned smooth chip. I replaced the PCB and drive is still unrecognizable. I did find a PCB with same FW and Site Code, but some chips are different. Do I need to replace these with chips from old PCB? If so, which ones?
Thanks!
Dr Dave
 Post subject: Re: barracuda 7200.7 PCB repair
PostPosted: March 13th, 2008, 2:02
your problem will be the main amp control head
that goes inside the hard drive too
not worth doing unless you know how to do a head swap
PostPosted: March 13th, 2008, 3:13
Does the new smooth get hot?
PostPosted: March 13th, 2008, 3:24
Thank you, would you like to do it?
Dr Dave
PostPosted: March 13th, 2008, 3:26
Smooth does not get hot on the replacement PCB. It is fried and bubbled on the original...
Dr Dave
PostPosted: March 14th, 2008, 21:29
Try to swap an 8-pin ROM chip(25PVxxxx) from the bad PCB to the donor PCB.
PostPosted: March 15th, 2008, 7:04
Hi
a picture of the damaged and the replacement board would be helpful here...
PostPosted: March 16th, 2008, 13:59
On the new PCB what does the hdd do does it knock or does the motor spin or not .
Like PEPE said u if u take a snap of the PCB that is burned and the donor pcb as well it would be helpful .
Users browsing this forum: Majestic-12 [Bot] and 65 guests
