wd 40 always busy
March 25th, 2008, 19:35
hello guys.
I have a problem with wd400EB - 00CPF0.
I scanned it using mhdd and it is always BUSY.
I need help please.
thank u all
Re: wd 40 always busy
March 25th, 2008, 19:43
Hi
I should hear its sound uppon power up...
do u mean it doesn't even get out of BUSY after powering up?
March 26th, 2008, 2:33
when the hard drive spins up can you hear it
does it spin down or just keeps going
this sounds you got a faulty pcb board
might be open circuit on the power ic
but not to sure
March 26th, 2008, 6:06
thank u pepe and craig,
yes pepe it is not even get out of BUSY after powering up.
it doesn't complete the Recalibration sound.
I tried to change the PCB craig but nothing is happened.
thank u again friends
March 26th, 2008, 7:18
Hi
how much did u wait? Drive might need some minutes to pass badsectors in the SA... after that it should get ready.
March 26th, 2008, 9:21
Hi pepe
It is never get ready
I think it is SA problem
when i tried to press F2 to identify the hdd it is ( drive not ready NO DRSCE or DRDY )
Thanks for replying
March 26th, 2008, 13:24
Did u got IDNF or AMNF, ata register control errors? while tried to read any sector
Best Regards
March 26th, 2008, 16:05
hi beto
no I didn't got any errors the hdd still busy can not recieve DRSC or DRDY
thank u friend
March 26th, 2008, 16:47
When you swapped the PCB, did you try the donor PCB with & without the ROM?
A continuous BSY signal is a symptom of a corrupted ROM (among other things).
Jon
March 26th, 2008, 17:01
hello jono
but i already tried diffrent PCBs and have the same problem
thank u
March 26th, 2008, 17:03
Is it maybe a PREAMP problem ?????????
March 26th, 2008, 21:56
^no. do you have the same drive? hot spaw.
March 27th, 2008, 8:28
hello grig85
I did this already but I have the same problem
thank u for ur help
March 27th, 2008, 11:11
Gee, I wonder if the motor is up to speed . . . .
March 28th, 2008, 11:52
BUSY means drive started the task and that task remains unfinished. bad micro code in SA, and your drive is trying to load with it. got PC3000?
March 28th, 2008, 13:40
Thank you grig
the answer for your last question is NO
I don't have one
thank you all friends
