 Post subject: Toshiba FDB (Fluid dynamic Bearing)
PostPosted: March 29th, 2008, 6:43
Hello to all,
I have problem with toshiba mk6032gax drive.Seems problem with FDB .it spins and generates a grinding noise and some time stops spinning too.I want to recover data from it.
Does anyone repairs these FDB?
Can anybody like help me in this.?
I will be very thanks full for any suggestion.
Thanks and Regards
 Post subject: Re: Toshiba FDB (Fluid dynamic Bearing)
PostPosted: March 29th, 2008, 10:30
We fix these by swapping the platters and heads into a comparable drive enclosure with a good motor.
Don't attempt it yourself without the proper tools and experience.
Jon
http://www.datasaversllc.com
PostPosted: March 29th, 2008, 12:41
Replacement of the motor is also possible, unless it destroyed a motor cylinder.
www.datarecoveryne.com
PostPosted: March 29th, 2008, 17:22
Easier to swap the platters and heads.
Or there are tricks to get the motor running long enough to image the drive, they usually work for me 8/10 times ;-)
PostPosted: March 30th, 2008, 3:47
yes ,i would like know the tricks becuase i have not a donor with ok bearing right now..i would able to read some sector ..but it stop many time,so it is too hard to clone required sectors.Please help me my friend.
Thanks alot for all replys.
PostPosted: March 30th, 2008, 9:19
These drives are position sensitive. Try imaging the drive with it positioned vertically, with the cable coming out the bottom.
Jon
PostPosted: March 30th, 2008, 15:57
...or, for me, 10/10 consistently! (And I get to keep the motor running as long as necessary....)
Duncan
PostPosted: March 31st, 2008, 2:39
Duncan
hello Odiferous and pcimage
Friends,it will be more help full me if you would like to advice me,what should i have to do for clone this drive.?
Thanks and regards
PostPosted: March 31st, 2008, 2:42
hi jono-ats,
Thanks for advice ,i will try this.
:D
Users browsing this forum: Majestic-12 [Bot] and 66 guests
