 Post subject: Flash Samsung PALO
PostPosted: April 7th, 2008, 7:05
In case the flash has been seriously corrupted and/or totally wrong code in, anyone has succeeded in getting RDY or flashing again via IDE instead of desoldering, programming externally and resoldering ? Emg. mode doesn't work neither attempt to wakeup the drive, and the problem is just the ROM.
I think something is inside the Syscon chip (MCU) because it would be expensive to program roms externally and then solder...
 Post subject: Re: Flash Samsung PALO - SOLVED
PostPosted: April 7th, 2008, 15:19
Found the way. :D YES WE CAN. :good:
Users browsing this forum: Majestic-12 [Bot] and 65 guests
