 Post subject: Need some advice
PostPosted: April 6th, 2008, 1:19
Hey everyone, I am a little new to this whole recovery thing. I am working on a diamondmax plus8 40gb drive. I have tried media tools, mhdd and ontrack easy recovery. None of the programs are even seeing the drive. It spins and doesnt sound horrible so, Would the pcb be the most likely culprit? I thought it might just because it cant even be identified. I have been looking on the forums and am wondering if I can use any other pcbs for this. It is a b8fea. Any thoughts or opinions would be greatly appreciated.
Thanks,
jerkykid
 Post subject: Re: Need some advice
PostPosted: April 6th, 2008, 4:17
is ur hdd detected by bios?
if detected wht does it shows?
u have to explain elaborately.
wht do u need from the hd?
Data recovery or repair the hd?
SHAHI
shahij@gmail.com
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: April 6th, 2008, 5:42
It is not detected by anything not by the bios or anything else.
I want to repair the drive and recover all of my files off of it.
PostPosted: April 7th, 2008, 0:57
Do you guys think I should try a pcb?
PostPosted: April 7th, 2008, 9:17
Probably you got a firmware problem, so if you don't have the proper tools (expensive ones) you should take your drive into a data recovery company.
PostPosted: April 7th, 2008, 11:13
Isnt firmware stored on the pcb?
PostPosted: April 7th, 2008, 11:18
In many cases not; and surtenly not for this maxtor.
Sorry, but you need special tools and good knowledge of them to repair this drive.
Dobre
Murphy was an optimist
PostPosted: April 7th, 2008, 12:21
does the drive even spin up?
PostPosted: April 7th, 2008, 13:36
The drive spins up everything sounds nornal no abnormal clicking or anything. The drive just cant be seen. This is the first time I havent been able to get into a drive using media tools.. Do I have any other options?
PostPosted: April 8th, 2008, 15:04
NO.
Further attempts can probably damage data. If it is REALLY important ask a pro. And likely it won't be for free. Sadly, sometimes the best we can do is not enough.
Regards.
PostPosted: April 8th, 2008, 16:41
SHAHI
shahij@gmail.com
Shahij,
You really should know better before you offer your opinion or advice; in the data recovery business, there is no such thing as "repairing" a hard drive.
It is only EVER "made good" for long enough to extract / recover the data. After that, it's in the bin or warranty replacement. Never, ever to be used again.
Duncan
PostPosted: April 12th, 2008, 14:03
Hi
There could be one method, but it is surely not the easiest one.
HotSwap
Cloning to a second drive
rebuilding the correct LBA space to a third drive
recovering data logically
U don't need anything expensive to do this, just some programming skills and lots of time.
I also suggest taking the drive to a pro if the data is important and urgent.
U can mess up things even more making the recovery impossible.
Users browsing this forum: Majestic-12 [Bot] and 64 guests
