 Post subject: 2 WD4000YR drives with different issues
PostPosted: April 15th, 2008, 12:04
Hello all, I have two WD4000YR drives. Both died with in a month of each other with different issues. Their warrintees run out in November this year so I would like to try to get the data off the drives before I send them back.
Drive one:
Was having a problem reading past the first sector but was picking up ok. Now when I tried it today I get a click every 3 or 4 seconds. But is constant and does not stop after 5 or so.
Drive two:
This one does not pick up in the OS or BIOS. It spins up ok. But just does not pick up. I have tried connecting Via a USB adapter but get the same thing. Tried a few different OS's Windows XP, Vista, DOS (it crashes out when it tires to detect the drive) and Linux. Although it was a stripped down Linux and I was not unfamiliar with it.
Any thoughts on OS's of software I can try.
Oh and I have also swapped out the PCB's for the two drives with each others. But they get same problems as before the swap. So no change on each drive.
Users browsing this forum: Majestic-12 [Bot] and 69 guests
