 Post subject: WD 250JB Platters Moter
PostPosted: May 17th, 2008, 16:19
Platters Moter don't start ,
i check the PCB ,I check the Platters, i check the Heads everything OK!
but the Moter don't spin...
Any idea ....
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: WD 250JB Platters Moter
PostPosted: May 17th, 2008, 19:21
Did you replace the PCB? Does the spindle spin manually? Have you checked the motor windings with a multimeter?
PostPosted: May 18th, 2008, 2:02
yes i check all that ...
what you means manual , "if turn , yes it's turn "
i know , i think I'm sure is the moter...
what I do not know is with what way i must changed without problem "do not lose the step from platters"..
PostPosted: May 18th, 2008, 9:37
If you're looking for a way to swap platters, Salvation sells a tool.
PostPosted: May 19th, 2008, 0:04
WD250s generally have 6 heads. Swapping platters is not recommended if you are an amateur and you really need the data. That's a lot of heads to load and unload simultaneously.
Jono
http://www.datasaversllc.com
Users browsing this forum: No registered users and 175 guests
