 Post subject: problem with 40 gb Toshiba HDD2190 weird fault
PostPosted: May 31st, 2008, 23:54
ok got a laptop hard drive in 40 gb Toshiba HDD2190
the hard drive pickes up in the bios fine no problems etc
but windows does not see it or any data recovery programs.
now if i boot up into dos the drive can be seen and i tried copying the drive over
with copyr.dma
it shows it copying but it does not advance in the bar.
other weird problem is that it coming up no system files the hard drive is blanked.
so now im thinking it could be a read head problem that is at fault
this will be our next step
just wondering if any of you have come across this problem before
 Post subject: Re: problem with 40 gb Toshiba HDD2190 weird fault
PostPosted: June 1st, 2008, 17:41
Most of these old Toshiba drives have bearing failures. The motor won't get up to speed and hence it won't allow data transfer.
Jon
http://www.datasaversllc.com
PostPosted: June 1st, 2008, 19:49
ok cheers for the information
it looks like it going to be the motor at fault.
as you where saying.
logic board is working 100%
now the qeastion is how do we get the drive going again.
can i heat up the motor hoping that the drive works.
or do you think a platter swap is the only options.
can you tell us does this hard drive have one head or two heads
thank you for your help :D
PostPosted: June 2nd, 2008, 10:22
To find out how many heads, etc. Google a Toshiba spec sheet.
Some people have success with heating up the motor bearing, but I never did.
Platter swap is not the only option with this drive.
Jon
Users browsing this forum: Google [Bot] and 56 guests
