 Post subject: Seagate Barracuda ST39175LW SCSI
PostPosted: June 12th, 2008, 9:52
I receive this HDD dead from a customer. Managed to obtain another with matching model, Part No. & firmware version. With a PCB swap, the customer disk can now spin up but it times out being recognised in the Adaptec SCSI BIOS. Only once could I get it to detect with a warm boot, but data not accessible.
Is there other detail I need to match for a compatible PCB or any other suggestions to recover this?
 Post subject: Re: Seagate Barracuda ST39175LW SCSI
PostPosted: June 12th, 2008, 11:55
Tried to check with mhdd if hdd its fully identified if its ok, tried to did a read test and check if u can access sectors
Best regards
PostPosted: June 12th, 2008, 14:49
Most Seagate SCSI drives have a translation corruption.
Typical synthoms are:
- Drive spins up
- Drive is detecte by SCSI adapter without size.
If so, you could try to resolved it using PC3000 SCSI Complex..... I have resolved over dozen drives that way.
If you don“t have pc3000 scsi complex, you should send it to someone who has it.
Good luck
Users browsing this forum: Google [Bot] and 65 guests
