 Post subject: debug.exe commands for unlocking hdd password
PostPosted: April 24th, 2008, 13:59
seagate command list is available in this website download area , thanks to who ever submitted it , but , i cant get the hang of things , i cant understand it very well , so please some one help , i know that you could send raw commands using debug.exe to the hdd in ata mode , to unlock the password , (i dont care about the data , i just want to be able to use my hdd again , ) so could any one of you guru's help me to do it , i cant afford to buy a pc3000 or salvation data for just one hdd , it doesnt worth it ,
i need to get what commands i should input to unlock the hdd using the debug.exe ,
thanks in forward
 Post subject: Re: debug.exe commands for unlocking hdd password
PostPosted: April 28th, 2008, 11:58
Here is an example of ata commands from debug
http://mirror.href.com/thestarman/asm/d ... script.htm
now to actually unlock it, that will take considerably more research
PostPosted: April 28th, 2008, 12:00
You could also ask this guy
http://sandeep-vaniya.blogspot.com/2008 ... ty_21.html
PostPosted: April 29th, 2008, 8:58
:lol: Yeah he is proper clever
I quote from his website:-
Monday, April 21, 2008
Unbreakable Security
The security feature supported in hard disk is unbreakable. Nobody can apply bruteforce/dictionary attack on your locked hard disk because
First of all one don't have low level utility to give unlocking commands to hard disk.
Even if one got the utility and do the bruteforce/dictionary attack, will get mad because at every sixth attempt hard disk needs to be applied hard reset. Security unlock command will be aborted if five wrong attempts are committed. After that, giving security unlock command results in command aborted until hard reset.
Maximum password length can be as long as 32 characters.
It has two security levels, high and maximum. And two password types, user password and master password.
Posted by Sandeep B. Vaniya at 6:07 AM
PostPosted: April 29th, 2008, 11:09
Where Mr. Vaniya sees an impossibility, I simply see an engineering challenge.
PostPosted: June 18th, 2008, 7:27
I'm unable to find this list in the website. There's not already uploaded?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 63 guests
