 Post subject: Hard drive size wrong and can't resize
PostPosted: March 28th, 2008, 12:40
I have a 320gb seagate (model ST3250625A) which I use as a second backup harddrive and as a hard drive for running different linux distros (there are 3 partitions on there). I also have a maxtor one touch 200gb external drive. The 200gb external was recently acting up and so assuming it was the drive I took it apart and loaded the enclosure with the 320gb seagate.
When I connected the external via USB (with the 320gb inside) only 1 partition came up as 128gb RAW. So I removed the drive from the enclosure and connected it back inside the computer and now it is still being seen as 128gb with 1 partition. I verified in the bios and it also recognizes the drive as 128gb. A little bit of research later and here is where I am at.
I've tried using Seatools (floppy boot) and MHDD (with the NHPA command) to resize the drive to it's native size, which I can see is supposed to be larger than what it's at, but the process fails with a prompt to cycle power to the drive. Doing so doesn't change anything.
Anyone have any suggestions how I can get my drive back to it's original size? Even if I can, any chance the data can be restored? I have it all backed up but it would still save the hassle of re-backing up everything.
 Post subject: Re: Hard drive size wrong and can't resize
PostPosted: March 28th, 2008, 16:56
Hi showcaser,
there's a drive size and a partition size.
When you run famous MHDD program what SIZE (as in LBA - CHS) does the drive report ?
PostPosted: March 28th, 2008, 17:23
Thanks for your help coffeebean. Some more details:
MHDD reports:
LBA: 268,433,408
Native maximum LBA adress: 488,397,167
If I try NHPA and select 'y' to set the max LBA to native I get:
Working...
Fail. Try to re-power HDD
Done.
I had a similar response is SeaTools which couldn't resize the max LBA and said to cycle power to the drive. I've tried re-starting the computer, unplugging, etc... Still says the same thing.
PostPosted: March 29th, 2008, 13:56
Can you give information about your external hd in details?
When u connected the hd with the pc as IDE/SATA (i m not sure), the bios limitation might occured this. try to connect the hd with another updated pc
OR
there might problem MOD # 57 or few more at SA.
SHAHI
BANGLADESH
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: March 29th, 2008, 16:30
Hi Shahij,
the external drive is a Maxtor one touch (around 4 years old) the drive itself in the external is a 200gb Diamond Max Plus 9. Both drives are IDE.
When I put the seagate 320gb in the maxtor enclosure and powered it up I imagine it must have messed up some parameter in the 320gb.
What does MOD #57 or SA mean?? How would I change it?
PostPosted: March 31st, 2008, 3:18
Try "HDD Capacity Restore" utility.
In my case that worked.
Dobre
Murphy was an optimist
PostPosted: March 31st, 2008, 19:55
Dobre
Thanks Dobre!
"HDD Capacity Restore" worked like a charm. Real easy too with the windows installer. And yet another plus is that all my partitions and data remained intact.
Thanks again!
PostPosted: April 1st, 2008, 3:49
Glad it worked.
Dobre
PostPosted: June 19th, 2008, 4:25
Do you think that tool can restore manufacturer native capacity?
PostPosted: June 19th, 2008, 5:38
Well, this tool should be able to do it, if the disk hardware is OK.
Dobre
Users browsing this forum: Majestic-12 [Bot] and 58 guests
