 Post subject: Toshiba MK6026GAS
PostPosted: June 18th, 2008, 23:07
Hi Guys,
This Toshiba hdd first did not spin up at all, no busy register - nothing. So I repaired the fuse. Now it goes busy, then all status registers go on. Anyone seen this before?
I know the adaptives are held on the processor. Am I screwed if it won't boot?
Thanks,
A
 Post subject: Re: Toshiba MK6026GAS
PostPosted: June 19th, 2008, 8:54
u can unsolder ROM and put on a Donnor PCB, could be another damaged on the PCB, if u PCB doesnt has serial ROM, u need to unsolder ARM chip and soldered on donnor
Best Regards
PostPosted: June 19th, 2008, 9:00
Silly question, but have you set the CS jumper on PC3000?
And tried on a regular PC?
Sean
PostPosted: June 19th, 2008, 9:55
Thanks Beto and Sean. I think it was a jumper issue. I fired it up in DeepSpar and it took off.
Cheers!
A
PostPosted: June 19th, 2008, 14:47
PostPosted: June 20th, 2008, 10:05
great acforensic,
best regards
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 67 guests
