 Post subject: Salvationdata Data Recovery Mate Review
PostPosted: November 21st, 2007, 12:54
Hi guys , Please see attached test Report. Any suggestions , Tips or additional information welcome. I am sure expert members like acforensics will be able to make more technical analysis.
Thanks in advance.
hddbug
File comment: Hard disk Details
File comment: Board Details
File comment: Test report
Salvationdata Data Recovery Mate Test.doc [26.47 KiB]
Downloaded 527 times
 Post subject: Re: Salvationdata Data Recovery Mate Review
PostPosted: December 2nd, 2007, 1:42
Looks good so far. Need more testing(does SD have any published results?). I'd like to let Linux have a crack at it.
My $0.02.
A
PostPosted: December 2nd, 2007, 11:36
Thanks acforensics , I will try to get published results from salvationdata. Thanks
PostPosted: December 6th, 2007, 4:43
It seems OK . As SHA1 is not cracked yet. If both signatures match that means it has done right job. To be 100 % precise it is needed that in the process no smart parameters are modified.
PostPosted: June 25th, 2008, 4:40
the one we use is the image masster drive lock
which all forensic companys use
which blocks write commands
and that cost us around $275
only does ide
but this look a good product tooo :ookay:
Users browsing this forum: Majestic-12 [Bot] and 58 guests
