 Post subject: WD2500JB Problems
PostPosted: July 3rd, 2008, 0:18
Hi Group,
I am trying to get this drive working to get data off. It spins up, clicks once, then spins down. I have a donor for this drive and was able to hotswap the drive to scan the modules. Many of them had errors, so I used the donor modules to repair them (except 20, 22,23,25,43 and 44 since they are unique). After repairing, I rescanned and got no errors. I restarted the drive and got the same thing - spin up, click, spin down.
Any ideas?
Thanks for responses.
 Post subject: Re: WD2500JB Problems
PostPosted: July 3rd, 2008, 2:46
Model: (MDL:) ?
After hot swap (to work with modules) U use native ~Dir (module 41), or ~Dir from donor?
Mikippp
PostPosted: July 3rd, 2008, 7:08
Hi Mikippp,
The full model is WD2500JB-00FUA0. I used the donor's module layout I believe. All I did was hotswap in Salvation data tool and scanned fw, fixed the ones that were damaged. Are you suggesting I check out these to see if some of the modules are allocated to different areas?
A
PostPosted: July 3rd, 2008, 7:25
I would start leaning towards a spindle motor problem here guys.
Users browsing this forum: Majestic-12 [Bot] and 60 guests
